Cruise and Overdrive Issue
Old Jun 3, 2019 | 04:52 PM
Cale Turner 66's Avatar
Cale Turner 66
Compression test netted no answers. All cylinders had good compression. Mine is the 5.7 Hemi.
Old Jun 3, 2019 | 07:40 PM
Ah, "tensioners" threw me for a loop.
Are you getting spark?
Old Jun 4, 2019 | 01:38 PM
Cale Turner 66
Yes, it will actually start and run. Just will not idle. Once you get it up over 1500 RPM it sounds just fine but as soon as you let off gas it dies. The more you do it the harder starting it becomes. Have to give it gas to start.
Dodge said it needed a new PCM. I am wondering if the PCM would cause the issues that I am having now.
Old Jun 5, 2019 | 07:18 AM
Anything is possible. Is yours the 'throttle by wire' system? (no cable from gas pedal to throttle body, all electronically controlled.)
Old Jun 5, 2019 | 07:24 AM
Cale Turner 66
Yep the throttle body is all electronically controlled.
Old Jun 5, 2019 | 07:31 AM
May want to try giving the throttle body a very thorough cleaning first. (and reset the PCM as well.) See if that doesn't take care of it.
