Erro code po222
Old Apr 12, 2019 | 04:32 PM
Derrick d's Avatar
Derrick d
Default Erro code po222
Put a new camshaft and lifters in i have sever codes poping up now never had. Them code.po108
Po113
Po123
Po222
Last edited by Derrick d; Apr 12, 2019 at 04:33 PM. Reason: Can someone point me in the wright way
Old Apr 12, 2019 | 04:34 PM
Derrick d's Avatar
Derrick d
Old Apr 12, 2019 | 04:58 PM
P0113: IAT sensor.
P0123: Throttle position sensor.
P0222: Throttle pedal position sensor...
Make sure everything is plugged in properly.
Old Apr 12, 2019 | 08:04 PM
72rtchallenger's Avatar
72rtchallenger
P0108 Possible causes---- Faulty Manifold Absolute Pressure sensor--- Manifold Absolute Pressure harness is open or shorted---- Manifold Absolute Pressure sensor circuit poor electrical connection----- Faulty Engine Control Module (ECM)
With all the work you just did and other codes I would go over wiring and plugs that you were working around for breaks or that have shorted out
Old Apr 12, 2019 | 08:38 PM
Yeah, a pinched harness somewhere seems perfectly reasonable.
