What do you guys think is going on here?
Old May 11, 2019 | 04:59 PM
LilManSyndrome's Avatar
LilManSyndrome
Talking What do you guys think is going on here?
Hey people, im new to forums and new to trucks,
I just bought my first truck a week ago which is a 2005 dodge ram 4x4.
Everyone told me im an idiot for buying it because its older and i never worked with a wrench,
anyways
I just noticed today that my rear right wheel axle seal was leaking, probably because of the bearing went out
as i was down there i noticed fluid leaking out of the crack of what i think is the transmission where it connects
to the .... (I dont know what its called) anyways its freaking me out
probably should of listened to everybody i had this truck for a week and i dont want it to s$%t the bed.
To my untrained eyes, it looks like a seal or gasket that has failed.
What do you guys think? Any input on the matter is much appreciated!
Old May 12, 2019 | 08:45 AM
The part behind the trans is the transfer case. (4x4 truck.) You likely have a seal going bad in either the rear of the trans, or the input hub on the t-case. T-case seal is easy to deal with, (once you have it out.....) trans seal? That one, I am not sure how much of an ordeal it is.
Old May 12, 2019 | 12:10 PM
fj5gtx's Avatar
fj5gtx
And looks like someone was already into that, given the still shiny grade 8 bolts. You gotta start somewhere, don't be shy about pulling things apart and repairing it.
Old May 12, 2019 | 01:26 PM
rebeltaz83's Avatar
rebeltaz83
That actually looks like a rear main, or pump seal. I believe that's the back of the oil pan I'm seeing. And the yolk where the front shaft attaches to the front diff. The pics are sideways.
Old May 12, 2019 | 08:32 PM
Ooops. You are indeed correct. Guess I need to drink more coffee before I look at pics.
Old Aug 23, 2019 | 04:00 PM
LilManSyndrome
It was the rear main seal leak thanks guys
Old Aug 23, 2019 | 09:39 PM
primem's Avatar
primem
wash it off and monitor it for a while before you dig into it. a rear main seal is a pretty big job. Drive the truck for a while and make sure the engine and trans are ok before pulling a trans to change the rear main seal.
