Drive belt whine, replaced pulleys, could there be a bigger problem? (video)
Old May 26, 2019 | 01:01 PM
CMA's Avatar
CMA
Default Drive belt whine, replaced pulleys, could there be a bigger problem? (video)
07 Dodge Ram Hemi, 60K. Have kept on top of all maintenance.
Yesterday drive belt started squealing. Spray water on belt, squealing stops.
Inspected pulleys, there was minor play in idlers and tensioner pulleys, so replaced them. Belt appears fine, no signs of wear. Have a new one, haven't installed yet.
Still squealing a little bit. Inspect AC compressor, alternator, and they do not have any play, seem solid.
Watching motor run, see that belt is "walking" on the center fan pulley. There is also an intermittent knocking or chugging sound (cant really hear in video). It appears that the central fan pulley may be moving in/out slightly.
There is no CEL, motor runs smooth. Truck has not been abused, driven softly most of its life.
If pulleys are new, accessories don't have any play, yet its still squealing and the fan seems to have some in/out play, what could be going on?
Old May 26, 2019 | 01:34 PM
CMA's Avatar
CMA
There is wobble in the fan. Appears that I need a new water pump, unless a little wobble is normal? There aren't any water leaks afaik.
What other services are done at the same time with the water pump?
Old May 26, 2019 | 04:56 PM
Dodgevity's Avatar
Dodgevity
Take a look at these...
https://dodgeforum.com/forum/2nd-gen...t-removal.html
https://dodgeforum.com/forum/2nd-gen...ic-losses.html
Old May 26, 2019 | 10:40 PM
CMA's Avatar
CMA
Thanks.
