radiator pressure
Old Jun 26, 2019 | 05:57 PM
rentub's Avatar
rentub
Default radiator pressure
What causes pressure in radiator when engine is cold ?
Old Jun 26, 2019 | 06:16 PM
If you get pressure immediately after startup, before the engine is even considering being warm, that's quite likely a blown head gasket.
What engine? What year is your truck? How many miles on it?
Old Jun 26, 2019 | 06:26 PM
rentub's Avatar
rentub
Hi. its a 2004 5.7 and has about 187,000 miles on it.
Old Jun 26, 2019 | 06:30 PM
You can rent/borrow a test kit from most any of the big chain auto parts stores, to test for combustion products in the coolant. I highly recommend you do so, and soon.
Old Jun 26, 2019 | 08:02 PM
rentub's Avatar
rentub
Thanks alot.
Old Jun 26, 2019 | 09:48 PM
Dodgevity's Avatar
Dodgevity
Yeah, if you leave the cap off and see coolant shooting out from a dead cold start, it's VERY likely the head gasket. The coolant circulates in a closed loop in the heads, etc., till the thermostat opens. There is no heat expansion of the liquid at this point, so that would be combustion pressure. Are you overheating? How does the oil and coolant look?
Old Jun 28, 2019 | 06:59 PM
rentub's Avatar
rentub
oil looks ok and its not overheating. i let it run with the cap off for about 1/2 hour and nothing happened .i have a PO480 code can the two be related?
Old Jun 28, 2019 | 08:18 PM
rentub's Avatar
rentub
oil looks ok and its not overheating. i let it run with the cap off and nothing happened .i have a PO480 code can the two be related?
Old Jun 28, 2019 | 09:47 PM
Do you have a cooling fan that is electric in any way, shape, form, or manner?
That shouldn't have the radiator building pressure right away. Do you see bubbles at the radiator neck while the engine is running?
Old Jun 29, 2019 | 10:03 AM
rentub's Avatar
rentub
Cooling fan only works when I hot it at the fuse box. Fuses and relay are ok. No bubbles with cap is off.
