acceleration issues
Old Aug 1, 2019 | 03:31 PM
twisted design's Avatar
twisted design
Default acceleration issues
I have a 2004 dodge ram 1500 4.7L 4 door. I am having issues with acceleration. when driving highway speed if i hard accelerate to pass it boggs down and will at times stall. when at stop sign if I hard accelerate it will do the same. I have been told its catalytic converter, I have also been told its egr valve. I suppose my real question is if I have a bad catalytic converter would it allow me to drive 70 75 on the highway? or do i have a gas flow issue ?? Or a egr Issue. One more history point i was having an issue with a rapid passenger side blinker it has stopped the same time my other issue started. I have done a past code test and it did show o2 sensor and injector issue on bank 2 I do not remember the codes exactly. Also i was told if its catalitic converter my gas mileage would be worse but it has not change may even be better because I am liter on the peddle.
Old Aug 1, 2019 | 06:42 PM
O2 sensors are very important for the engine to run properly. If you are still getting those codes, find out what they are, and fix 'em. Gotta start there.
