5.9l v8 magnum fuel rail
Old Aug 16, 2019 | 07:05 PM
Cmitchell1's Avatar
Cmitchell1
Default 5.9l v8 magnum fuel rail
I'm sure this has already been talked about cause I'm sure this is super common. I recently had my fuel line between the two rails blow a hole in it, I cannot find a replacement fuel rail anywhere... I was wondering where is a good place to get OEM rails or even aftermarket ones? Or can the line be replaced? I work at a salvage yard and the yards we do business with dont have any either. 😨
Old Aug 16, 2019 | 09:38 PM
How is the line held on at each end? Are there barb fittings the line is heated, and pushed on to? If so, just get some appropriate size high pressure fuel line, and some clamps.
Old Aug 17, 2019 | 04:36 PM
Cmitchell1's Avatar
Cmitchell1
It looks like it's just pressed on to barbs.
Old Aug 17, 2019 | 07:56 PM
If there are actually barbs, then some high pressure line, and a couple clamps for same, should take care of it.
