truck noises
Old Aug 28, 2019 | 02:28 PM
brownml85's Avatar
brownml85
Default truck noises
im getting front end grinding/ringing at about 50mph on my 2005 ram 3500 4x4, and just recently is squealing intermittently at around 70+ mph, but not always. need help, havent found anything similar online.
the ringing sounds kind of like a bell, and it happens at lower speeds also
Old Aug 28, 2019 | 06:24 PM
Where does it sound like it is coming from? Could try jacking up the front, and spinning things by hand. See if anything doesn't feel/sound quite right.
Old Sep 4, 2019 | 01:35 PM
brownml85's Avatar
brownml85
i think it may be the front drive shaft. can i just take it off if i dont need 4wd?
Old Sep 4, 2019 | 06:37 PM
Yep. Not a problem.
Old Sep 4, 2019 | 09:12 PM
ol' grouch's Avatar
ol' grouch
If you go to that much trouble, why not fix it and put it back on. Just in case you DO need 4X4 sometime. I just have this thing about things ought to work like they're designed. On another note, have you tried weaving at speed? Does the noise change going around a curve? If it gets louder one way and lessens the other, it may be a wheel bearing.
Old Sep 4, 2019 | 09:14 PM
brownml85's Avatar
brownml85
its the transfer case. it has holes gouged in the rear case cover...so hopefully a new cover is all i need...i already removed the front drive shaft, and theres no more noise
