Air Conditioning Issue-Help!
Old Aug 29, 2019 | 06:23 PM
FFEMT840's Avatar
FFEMT840
Default Air Conditioning Issue-Help!
Hey all,
I have a 2006 Dodge Ram Quad Cab with the Hemi that has 100k miles on it. Over the past month or so I have noticed that when I turn the truck on and turn the AC on it takes a while for the AC to blow cold. It blows fine. It just blows hot air at first and maybe after 5-20 minutes it will start cooling down. I am thinking that it is either the relay going bad or low on freon. Any ideas or thoughts? Any help is greatly appreciated. Thanks,
David
Old Aug 29, 2019 | 06:52 PM
jrsick's Avatar
jrsick
When it starts cooling down, is that while you are driving, or parked?
Old Aug 29, 2019 | 07:02 PM
FFEMT840's Avatar
FFEMT840
It is when I am driving that the AC cools down.
Old Aug 29, 2019 | 07:27 PM
fj5gtx's Avatar
fj5gtx
Check the refrigerant, the ac compression clutch is kicking in, and that the dedicated a/c condenser fan is operating.
Old Aug 30, 2019 | 02:34 AM
Alex Medeiros's Avatar
Alex Medeiros
Huh, typically it's the opposite in these trucks... I wonder if the ac condenser fan is running, or if the relay is shot...
Old Aug 30, 2019 | 07:03 AM
jrsick's Avatar
jrsick
Yep, probably the a/c condenser fan. Check to see if the a/c condenser fan is running when you are parked with the a/c on.
Fan motor is fairly easy to replace and not expensive.
But also check to see that the compressor is spinning, and that you can hear the a/c relay click when the a/c is turned on.
Old Aug 30, 2019 | 08:39 AM
FFEMT840's Avatar
FFEMT840
Thanks everyone. I will get on this first thing tonight when I get off of work.
Old Aug 30, 2019 | 08:48 AM
jrsick's Avatar
jrsick
Autozone carries the motor, I believe manufacturer is VDO and pn is 523.
