Need help
Old Sep 1, 2019 | 10:26 AM
Buddy01's Avatar
Buddy01
Default Need help
Will a 2007 5.7 hemi work in a 2004 with a 5.7 any difference
Old Sep 1, 2019 | 10:41 AM
ol' grouch's Avatar
ol' grouch
Is everything else the same? Transmission? 2 or 4WD?
Old Sep 1, 2019 | 10:46 AM
Buddy01's Avatar
Buddy01
Its a 2wd i found a 2007 out of a jeep its a 5.7 my ram has a 5.7 in it was looking at getting it but want to know if it will work in my truck an if i have to change anything ro make itwork
Old Sep 1, 2019 | 12:35 PM
ol' grouch's Avatar
ol' grouch
Someone else can tell you about if the computers will work or if you need to reflash. Since the bodies are different, you may need to swap the exhaust manifolds, intake and possible oil pan. The oil pan will be either a front, center or rear sump pan. If they look identical on the pan, you may not need to swap them. With the engine out, now would be a good time to check the expansion plugs, any oil leaks and generally clean the engine up. Personally, I'd drop the pan anyway just to check for debris or sludge.
Old Sep 1, 2019 | 02:57 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Is it a truck or car engine?
Old Sep 2, 2019 | 07:51 PM
fj5gtx's Avatar
fj5gtx
2007 could be MDS, depending on the donor. You don't have MDS on your 04, assuming you had a 04 hemi and not doing a retrofit.
