Fog lights problem
Old Sep 5, 2019 | 06:01 PM
Tim1500megacab's Avatar
Tim1500megacab
Default Fog lights problem
I have a 2006 mega cab and I can not figure out how to get my fog lights to come. The noble on the dash doesn’t push or pull.
Old Sep 5, 2019 | 06:27 PM
Do you have fog lights?
Old Sep 5, 2019 | 10:26 PM
Tim1500megacab
Yes it is factory wired. But I can’t find anyway to turn them on.
Old Sep 6, 2019 | 08:24 AM
fj5gtx's Avatar
fj5gtx
This is what google tells me is a replacment switch... pretty clear the fogs is a push operation on the ****. If yours doesn't work, buy a new one, they're like $25.
Old Sep 6, 2019 | 10:26 AM
Tim1500megacab
I don’t have that switch in my truck. Looks similar but does not have the push button on the noble. But all the wiring in the truck looks factory. Still has the star logo.
Old Sep 6, 2019 | 04:11 PM
TrueDogman's Avatar
TrueDogman
Maybe the wrong switch was mistakenly installed at some time ??
Old Sep 6, 2019 | 06:13 PM
fj5gtx's Avatar
fj5gtx
I upgraded my 2004 from not having fogs.... All I needed was the wire from the rad support pigtail to the lights, and a new switch. Get a new switch, it may already be all wired and ready to go. The only thing I have with mine is there is no dash feedback that they are on. I think that is a return from the cluster - not sure if the cluster is different or the harness... but the lights work fine. Good luck !
Old Sep 9, 2019 | 02:13 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Factory wired is one thing; was it built with them or did you add them? If it was built with them then you have the wrong switch. If you added them, then not only do you need the switch they but have to be enabled on the BUS.
