Dodge Ram P0171
Old Sep 18, 2019 | 01:39 AM
Kevin Nelson's Avatar
Kevin Nelson
Default Dodge Ram P0171
I have a 2003 Dodge ram 1500 with a 4.7l magnum v8, my truck would crank over and start and then sometimes it would just crank over. I finally got a p0335 code and changed out the crankshaft position sensor and now it starts and runs. But when I would first start it it would be sputtering and when I would put it in drive and hit the gas it would take a second to get acceleration, but once I drive it and it warms up it gets better. Then my check engine light would come on and now it's a p0171 which is fuel running to lean. Has anybody had this issue that could help me to figure it out.
Old Sep 18, 2019 | 09:57 PM
3rdgens4sell's Avatar
3rdgens4sell
Fuel pump most likely,clog or injector
Old Apr 11, 2022 | 04:03 PM
srt-4neonguy's Avatar
srt-4neonguy
Default 03 ram 1500 4.7l no start with p0335 code
im having an issue with my 03 dodge ram 1500 4.7l having a no start situation. it always throws the same code of p0335 (CKP). i replace the sensor 3 different times. I have changed the CMP, i have check the wiring to the plug and the plug itself and also i checked the toner wheel for breaks all good. at this point im pretty stumped i was thinking it could be a glitch in the ecu or sometime????
Old Apr 17, 2022 | 12:13 PM
lxman1's Avatar
lxman1
Site Moderator
It could possibly be a bad PCM.
