AC won’t turn on!
AC won’t turn on!
So I recently purchased my 2002 Dodge Ram 4.7 1500 and it has been well maintained. When I got the truck, my AC would only work on the high setting which I didn’t see too much of a problem because at least it worked and I live in Texas so anything is better than nothing. Well the wife and I went to Walmart yesterday and the ac was working fine on the way there but when we went to leave the ac wouldn’t turn on. I did some research and learned about the resistor so I pulled the old one out and it crumbled in my hands. Therefore I went to autozone and got a new one. Put it in and nothing. So then I started looking around more and checked relays and fuses and found the ac condenser fuse placement was melted where the fuse meets the contact points. I haven’t replaced the fuse box yet because it does still get power to the contact points. Today I was messing with it and the AC turned on for a split second then turned off. I don’t understand why the fuse box melted where the fuse goes or what might have cause this? Someone please help because I can’t drive around in 100 degree weather much longer without ac lol.
My suggestion is for whatever reason you had a poor connection at that fuse. Poor connections create heat. I might consider doing a little wiring and remove that portion from the fuse box. Install a heavy duty fuse holder to those two wires and mount or have it nearby the fuse block
...instead of replacing the complete fuse block ??
You probably have two issues. The blower motor resistor block is failing. That's why it only works on high. It's a common failure, High speed is the default setting. In addition, I'll bet the melted part of the fuse connector is on the supply side. If it was the low side, the fuse would have blown. I'm thinking (well....guessing) the constant high demand for current got it hot and something pushed it over the edge. You might be able to just rig around it but fuses are there for a reason.
While possible, an 18 year old truck that was well maintained shouldn't have an issue there. If it had sat in a barn for a few months over the winter, it might be possible. I suspect a bad blower motor resistor block just caused continuous heat that built up in hot weather. There's a lot of heat under the hood in the summer. That's why Chrysler has used heat barriers for decades on the battery.
When I drove a truck back in the early 70's out west, I'd cook on the engine. Dinty Moore stew was very popular, although some people would forget to poke a steam hole in the can and it would explode. Myself, I remember once during the winter, I got some hamburger meat and made long patties to fit on hoagie buns. I'd cook them medium well and wrap in several layers of aluminum foil. At least 4 or 5. I'd store them in the freezer where I was renting a room. When I wanted one for lunch, I'd put them on the exhaust manifold and drive. Stop about every 50 miles and turn. After 200 miles, they would be well done and hot. A bag of chps and a soft drink and while the other drivers were eating, well, food isn't the best word, I'd have a fresh burger. Just shaped funny.
Trending Topics
