Heater question for the Gurus
Old Sep 23, 2019 | 08:33 AM
Sequoiha's Avatar
Sequoiha
Default Heater question for the Gurus
2006 Hemi 5.7 SLT dom (09/05) Heater does not work, only cold air from any vent on any setting, A/C works great, all vents switch good, Engine maintains normal operating temp, just no heater, Just started, or I just noticed, worked fine last year.. I have deer season coming up and for sure need a heater,
Old Sep 23, 2019 | 09:27 AM
ol' grouch's Avatar
ol' grouch
First and foremost, make sure the cooling system is full. Next, make sure the heater hoses are both hot. If the system is full and both hoses are hot, your heat blend door may be stuck or broken.
Old Sep 23, 2019 | 09:44 AM
cruzer55's Avatar
cruzer55
Pull the ****,check the back side for broke or cracked mount.I,ve had a few at the shop that all was needed,new ****.Just a thought...............
Old Sep 23, 2019 | 12:37 PM
Sequoiha's Avatar
Sequoiha
Thanks , I’ll check the hoses, the system is full, topped it off first.
Old Sep 23, 2019 | 12:39 PM
Sequoiha's Avatar
Sequoiha
Didn’t think of that. Thanks.
Old Sep 23, 2019 | 12:40 PM
Sequoiha's Avatar
Sequoiha
If it is the blend door, hard to address or not.
Old Sep 23, 2019 | 03:37 PM
gr8scott72's Avatar
gr8scott72
I recently took the whole dash off and the hvac box off to replace the evap core. While there I replaced the heater core, all the blend doors, and the blower motor.
It's quite a lengthy project but with the videos on YouTube, it's very straight forward. All those parts I listed set me back right at $600 and it took me most of a weekend to do.
Old Sep 23, 2019 | 06:48 PM
Sequoiha's Avatar
Sequoiha
I drove home from work, top radiator hose was way hot. Both heater hoses not so much. Warm at best. **** is not cracked. What now.
Old Sep 23, 2019 | 07:03 PM
Backflush the heater core. See if anything interesting comes out. Is the core original??
Old Sep 23, 2019 | 07:56 PM
Sequoiha's Avatar
Sequoiha
Yes, it is original. 240,000 miles.
