Transmission problem
Old Sep 24, 2019 | 04:20 PM
caden cross's Avatar
caden cross
Default Transmission problem
I got a 2005 Dodge Ram 2500 quad cab long bed with the 5.7 Hemi and a 545rfe transmission. We recently rebuilt the transmission and put a new torque converter in and now about 4000 miles later, we have a problem. It will start in 3rd gear and not downshift. I have tried replacing the solenoid pack and that didn’t do anything. I think it may be because I have a broken connector that plugs into the solenoid, the plugs fine it’s just the locking mechanism that keeps it from popping off. Would it possibly not be getting a good connection? When I take the connector off and plug it back in, the truck will work fine for about a 1/4 mile then just lock back into 3rd. What do you think this is? Thanks
Old Sep 24, 2019 | 06:34 PM
Should be setting codes if it is going into limp mode.
Old Sep 24, 2019 | 10:25 PM
caden cross
Default Codes
Yes there are codes
po700
po750
and sometimes there is a code called “no j1850 transmission”
sorry I’ve should of included those in original thread.
Old Sep 24, 2019 | 11:44 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
1. Have you checked ALL electrical connections, especially to make sure the big locking connector was locked down properly?
2. Was a quick learn performed after install?
J1850 message means there is a communications interrupt on the bus, this usually happens because a communication wire is either cut or being shorted to ground. Good chance something got pinched during install.
Old Sep 25, 2019 | 12:02 PM
caden cross
Yes I bought the big locking connector(my last one did not lock because it was broke) and the input and output speed sensors. I will also check for any shorts or any damaged wires. Thanks for the help I will let you know if this works.
Old Sep 25, 2019 | 12:04 PM
caden cross
And also I did try and do a quick learn with a expensive scanner. But it wouldn’t work it kept saying communications error, but everything else would work on scanner.
Old Sep 27, 2019 | 04:05 PM
caden cross
Ok so I just put in the locking connector and the 2 speed sensors. Now it still starts in 3rd gear and only has one code now, po750. I tried doing the quick learn again on my Autel scanner and it says “cannot be running” Any ideas
