Misfire issues
Old Oct 2, 2019 | 09:17 AM
Grimace71's Avatar
Grimace71
Default Misfire issues
Need help friend went through water. Ran rough on way home had 6 misfire codes we changed the plugs and coils run awesome for one day only then same codes came up with same cylinders. Was needing help any help would be appreciated. It's a 2002 4.7
Old Oct 2, 2019 | 11:07 AM
Dodge did not have a 4.7 in a ram.....at any rate, I would do a compression check. How high was the water? Did it get sucked into the intake?
Old Oct 2, 2019 | 04:38 PM
72rtchallenger's Avatar
72rtchallenger
I believe that only the ram 1500 had the 4.7 in the ram series in some models as I know of several , but perhaps look under the truck and see if there are any type of loose wiring that may interfere with the running and check the intake as stated and did you change plug wires as well ? Maybe double chech connections to the plugs an coils an make sure its all plugged in properly
Old Oct 3, 2019 | 07:31 AM
My bad.....I was thinking about a 4.6...In a Ford of all things....lmao
Old Oct 4, 2019 | 07:07 AM
gcburkett's Avatar
gcburkett
Unless it died while in the water, I would not expect mechanical damage. You should check the air filter to make sure its dry. Its a little strange that changing the plugs and coils improved it for a while.
I would think about sensors getting wet and retaining somewhat conductive water. Probably would not hurt to check for moisture in the crank and cam sensors connectors.
Old Oct 4, 2019 | 08:03 AM
Ken Trulsen's Avatar
Ken Trulsen
Default Misfire
We changed the plugs and coil packs run better than ever before then the next day all the codes came back all with the same misfiring cylinders . Never checked the intake yet but why would it run perfect for the one day ?
Old Oct 4, 2019 | 09:47 AM
Ken Trulsen
Default Misfire
Sorry it was a week later that it came back with the same cylinders coming up bad
Old Oct 4, 2019 | 10:06 AM
Miyokorei's Avatar
Miyokorei
Doesn't that truck have a distributor cap? Maybe its loose or damaged and is getting moisture under it causing the multiple cylinder misfire. You already did plug and wires, so I would just change out the cap and rotor while your at it.
Old Oct 4, 2019 | 11:32 AM
66three83's Avatar
66three83
I was thinking, WTF is he talking about????
Old Oct 5, 2019 | 06:02 AM
gcburkett's Avatar
gcburkett
When you changed the plugs did you disconnect the battery? If so that might have reset the fuel trim mappings.
I would want to look at live data to continue diagnostic before additional parts but checking for moisture in electrical connectors does not cost any money and is pretty quick.
