Steering Returnability
Old Oct 12, 2019 | 05:26 PM
scochran269's Avatar
scochran269
What should it read? I don't know what 'in Spec" would look like
Old Oct 12, 2019 | 08:02 PM
Originally Posted by scochran269
You're looking at Camber, not Caster...caster is 2.8 and 3.2
DOH! You are quite right. I must need more coffee.....
Old Oct 12, 2019 | 08:06 PM
primem's Avatar
primem
spec is 3 to 4 on the left and 3.4 to 4.4 on the right. higher on the right to compesate for road crown. it a little low but the point being if I came in with the problem you had...I would set it higher. Is the 0.2 that is out going to make a difference no...but if you cranked it to the max it would return better.
make sure the tires are properly inflated low tire psi makes the steering heavier.
