07 1500 5.7 smoke, shudder, fouled plugs
Old Nov 3, 2019 | 07:49 PM
cafilener's Avatar
cafilener
That damaged plug was from 1. I will do as you suggested and check it out with the rockers off. Definitely looks like it would be easier to pull the heads with the engine out, but I bet it can be done. Trying to find a corner out of the wind for this project, it's a little involved for a curbside job in the winter here.
Old Nov 3, 2019 | 08:50 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a valve issue. I don’t know if possibly the MDS system is holding the valves open or not. I can’t remember if the MDS holds the valves open or shut when it is activated. Hopefully it’s something cheap and easy to repair.
Old Nov 16, 2019 | 06:49 PM
cafilener's Avatar
cafilener
TrueDogman,
I loosened the rockers up, and that seemed to let the exhaust valve close. Must not've been quite TDC. Now I have air (doesn't seem like a lot) coming out the oil cap. Rings? I didn't get better compression with oil in the cylinder, so not sure this is lining up.
Old Nov 16, 2019 | 08:00 PM
Pull the plugs out of all the cylinders, and run your compression test again with the rockers loose. See what ya get.
Old Nov 17, 2019 | 12:45 PM
cafilener's Avatar
cafilener
Still a big zero on that one. Going to go do 3,5, and 7 since i am there.
Old Nov 18, 2019 | 05:28 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a plan
