2005 4.7L tick? Knock? ???
Old Oct 31, 2019 | 06:48 AM
bdhuntr's Avatar
bdhuntr
Default 2005 4.7L tick? Knock? ???
First off, it’s been a while. I relocated from MD to TX in June so been pretty busy.
Didn’t drive the truck to TX (had it moved) so it’s not like I overtaxed the engine with 174K on the odo. It’s always had the tick on start-up that goes away in a few seconds. Went to Lowe’s this past weekend and while driving (especially when passing cars or near a Jersey wall) I heard a constant tick. It did not seem to get louder or faster as engine speed increased. When I got home I had my wife accelerate the engine while I was underneath, and to me it sounded like it was coming from the right side.
Yesterday I went out and ran the engine while parked until it came to operating temp. I only heard it when rapidly accelerating, and only at the initial acceleration. Even at 4000 rpm it sounded good. I just hear that initial tick (sounds like castenets) upon initial rapid acceleration.
i’m thinking not an exhaust leak as that should leak all the time. And a rod would be louder and more banging than ticking. I have no codes and other than that tick, engine performance is normal. Do you think this could be a sticking lifter? I don’t think so, but maybe.
I’m open to suggestions.
Old Nov 8, 2019 | 08:29 AM
bdhuntr's Avatar
bdhuntr
Any ideas?
Old Nov 8, 2019 | 08:39 AM
Spark knock? How old are your spark plugs?
Old Nov 8, 2019 | 08:22 PM
bdhuntr's Avatar
bdhuntr
At least two years old, but probably less than 5-7K miles on them. And I would say it does not sound like engine knock (detonation). That’s a distinct sound for sure.
i tried to record the sound but it did not come out well. Does the exhaust leak tick only make noise when under a load but not when revving in neutral?
Old Nov 8, 2019 | 08:57 PM
Maybe, depends on how bad it is. Might be able to see it at night though...
Old Nov 12, 2019 | 02:51 PM
bdhuntr's Avatar
bdhuntr
Exhaust leak. Right manifold but not from broken/missing bolts. About 1/2 way down the right side. Manifold very corroded and needs to be replaced as well.
