check engine light
Old Dec 31, 2019 | 10:15 AM
Doug Crockett's Avatar
Doug Crockett
Default check engine light
the check engine light on my 2002 dodge ram van 1500 will not go off for emissions test
Old Dec 31, 2019 | 12:00 PM
Alex Medeiros's Avatar
Alex Medeiros
First thing you'll need to do is get a scanner to see what code(s) you have.
Old Dec 31, 2019 | 05:44 PM
Exactly. Get the code read. It is telling you what’s wrong.
Old Dec 31, 2019 | 09:10 PM
72rtchallenger's Avatar
72rtchallenger
If you don't have your own scanner , you can get it done at a parts store like autozone for free or whatever parts house in you area , post the code would be helpful as it could be many things , common thing is usually an 02 sensor code but not every time ,, they can clear it with a good scanner or you can unhook your battery terminals for 20 minutes or so to clear , it may come right back or may stay off depending on issue , but you need to know the code first to see what caused it in the first place ,, even an loose fuel cap can set a code off , as well as many sensors or failed component
