front lower coil spring seats for 2006 Ram 1500?
Old Jan 9, 2020 | 07:19 PM
PlorkZ's Avatar
PlorkZ
Default front lower coil spring seats for 2006 Ram 1500?
I have to replace the shocks and struts on my 2006 Ram 1500 (4x4 crew cab) and I decided I wanted Bilstein, the only problem is they don't make complete front strut assemblies and their struts don't include the lower spring seat (the metal flange that the spring sits on, not the rubber or nylon isolator). Bilstein told me I would be able to re-use the seats from the old struts as long as they were original because those were removable. As it turns out the struts that were on my truck were not original that won't work. It looks like nobody makes those spring seats, I can't find them from any aftermarket supplier and the dodge dealership says they don't make them any more, and I can't find any from a salvage yard, ebay, etc. Does anybody know where I could find these spring seats or am I stuck trying to return these Bilstein struts because they're completely useless? Thank you!
Old Jan 9, 2020 | 08:10 PM
Could you post a pic of your front suspension? I can't find a useful parts diagram.... can you link one?
Old Jan 9, 2020 | 10:45 PM
PlorkZ's Avatar
PlorkZ
Unfortunately I wasn't able to find a diagram either. I don't have any pictures of my front suspension because I have the struts at the local shop, they were going to build the assemblies for me but nobody can find the parts. I'll try to get actual pics when I can, but here is a stock photo of what I'm looking for, the metal plate looks kind of like a top hat with the insulator and spring sitting on it.
Old Jan 10, 2020 | 12:17 PM
Can you get a part number for the dodge dealer?
Old Jan 11, 2020 | 11:50 PM
PlorkZ's Avatar
PlorkZ
I checked and the shop looked around too but I couldn’t get a part number. At this point I feel like my only options are to find an original set of struts in a salvage yard or have the seats custom fabricated, both of which are probably unrealistic.
Old Jan 12, 2020 | 09:50 AM
If you can find a truck in the junkyard..... should be able to get the spring seats from it. Car-part.com is a locator service, might check them out.
Another option would be to get 'loaded' struts. They come with springs already installed. Not inexpensive though......
