Do I need a new WIN Module?
Old Jan 23, 2020 | 09:55 AM
nembilongmiKelly's Avatar
nembilongmiKelly
Default Do I need a new WIN Module?
Hi there everybody, new to the forum here. I have a 2007 Dodge Ram 1500 with a 3.7. Earlier this fall we were having issues with a misfire in the truck. It was overdue for spark plugs so we replaced all of those. Truck did not misfire again right away, but it did misfire again, probably within the first two weeks of changing plugs. We decided to park it until we had time to really dive into what was going on.
Now I tried to charge the battery up and it didn't want to take a charge, so I replaced the battery (Battery was cracked and leaking fluid). Key will turn on lights, radio, windshield wipers, etc. but will do nothing when turned to start position. Also, lights do not dim when I turn the key to start position. I took the starter off and cleaned the connections and also bench-tested it. Put the starter back on the vehicle and jumped the starter to try to at least get the engine to turn over. Engine would turn but not start.
It seems like I am being locked out...which is why I suspect the WIN sensor. Any ideas?
