Need extended brake hoses for the front
Old Jan 27, 2020 | 08:54 PM
Prismatic's Avatar
Prismatic
Default Need extended brake hoses for the front
2003 1500 QC 5.7
Lifted 5 inches, brake lines are tight. Can't for the life of me find anything marketed towards my truck as far as extended brake hoses go.
Help?
Old Jan 27, 2020 | 09:01 PM
Mandotimelord's Avatar
Mandotimelord
Originally Posted by Prismatic
2003 1500 QC 5.7
Help?
Just a quicksearch on summitracing.com came up with this.
https://www.summitracing.com/nv/part...model/ram-1500
These are for a 4-6in lift.
Old Jan 27, 2020 | 09:31 PM
Prismatic's Avatar
Prismatic
Huh, my Google-fo must be on the fritz. I'll try those out, thanks
Old Jan 28, 2020 | 06:51 AM
Mandotimelord
All good, I skipped google because I knew summit racing would have the parts. We have one of their stores here locally and I’ve seen brake line kits in store before. Those are a little on the pricey side but just search around on their site. Their selection of, well, everything is quite extensive.
Hope you find what you’re looking for. 👍🏻
Old Jan 30, 2020 | 03:44 PM
Prismatic's Avatar
Prismatic
Brake lines were delivered today and installed. Perfect fit.
Thanks
Old Jan 30, 2020 | 06:47 PM
Mandotimelord
Thanks
Not a problem at all. First time I’ve helped someone here. Thank you.
Glad they worked out. Let’s see a picture of the lift?
Old Feb 1, 2020 | 04:51 AM
Prismatic's Avatar
Prismatic
You bet.
2003 1500 5.7 Quad Cab Laramie 4x4
5 inch Rough Country lift, rancho RS9000 shocks
Moto Metal 972 20x10 wheels wrapped in Falken Wildpeak AT3W 325/60/20 tires
U-Bar style headlights, 3 discrete 6" double row LED bars behind and under the grille, fogs replaced with 2x2 LED flood pods
Also has an onboard air system for those desert trips.
Edit - The truck mentioned (and shown) in my sig I sold after I got rear-ended.. Dodge for life
Old Feb 3, 2020 | 07:41 PM
Mandotimelord
ugghhh, this is goals for me. Unless I get into a diesel before then. Gorgeous.
