3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I had same symptoms and my problem was a bad pulley. The bad pulley created play in the belt and resulted in a squeak when turning and on start. Take a look at your serpentine belt and see if it sits centered on all pulleys. I'll bet your idler pulley is loose.
Belt is centered on all pulleys. The pulley is new. Symptoms started when power steering pump failed. Serpentine belt is also new.
