Heater issue - tried a lot of stuff already
What’s up I’m Mike. I purchased a 2003 Ram 1500 4.7L quad cab and I love it. I’ve been reading a lot on how to fix the heater issue but I just haven’t had any luck on this and I’m in need of more suggestions. Here’s a little background, AC works great, heater doesn’t blow hot air. I changed the thermostat, I flushed my heater core, coolant level is fine, I have my lower dash off right now, figured out that the blend door and one of the mode doors “stopping pins” notch were broken off, I changed those - still no heat. When my actuators are off, I can toggle the stopping pin and I can hear my doors opening and closing so I don’t think the doors are broke. I can also hear and see the blend door operate when I go from hot to cold. Both my heater hoses get hot when at operating temperature. What else could it be? Any suggestions I’m open to it , maybe my doors aren’t working right or just going half ways? I get heat for like 1 second then it goes cold . Thank you
My blower motor works and I can see my recirculation door opening and closing. My ac/heater control module works, but has anyone ever had an issue with just the heat on the control module not working? I’m just throwing that out there any tips would be helpful thanks
You know the coolant bleeder on the 4.7 .. in all the videos I seen people are able to open this up and remove the screw and let air bubbles release. but mine just gushes out coolant (cold engine). Prob has to do with high point but I’ve seen people completely remove this and look at the coolant without it gushing out all crazy. Anyone had something similar happen?
I’ll probably either cut into the box to more closely examine both blend doors, or I’ll have to drop the dash and if I do that I’ll just replace all the doors and heater core. Thanks for all the suggestions
