Replace lower ball joints on 2002 2wd
Old May 4, 2020 | 02:13 AM
Laura Mason's Avatar
Laura Mason
Default Replace lower ball joints on 2002 2wd
My 2002 2wd was eating lower tie rod ends and stabilizer links for about a year. The last time I replaced the lower tie rod end was about 1 and 1/2 yrs ago. Just replaced it again and continued to hear loud popping noise on drivers side. I pulled the tire off after jacking it up and putting the stands under for safety. I tugged on everything that I thought was suspicious, but nothing moved. THEN I noticed bright red grease coming from the boot of the bad ball joint. HA!! Diagnosed!!! WAS a difficult fix with a couple helpful strong men and special ball joint tools from Specialty Products Company and trucks back on the road!!!!
Old May 10, 2020 | 11:58 PM
Will_V2Lab's Avatar
Will_V2Lab
Do you know why your truck was going through lower tie rod ends and stabilizer links? Is the truck lowered or anything?
