05 ram 1500 speedometer not working
Old May 6, 2020 | 06:43 PM
Jeff Laib's Avatar
Jeff Laib
Default 05 ram 1500 speedometer not working
I have a 05 ram 1500 and I was driving to work and when I got there, the speedo stopped working and so did my climate control. The fan works but no heated mirrors or ac. I replaced my vss on the axle before I discovered the climate control issue. All I have for codes is p0501,vss performance issue. I did drive through a little water a few days before. I read somewhere that a red/black wire if corroded,will have these symptoms, I am wondering where on the fuse block it is and a fix is thanks
Old May 10, 2020 | 07:35 AM
95RAM360's Avatar
95RAM360
I was having my speedo cut in and out triggering abs and brake light. I check sensor looked fine, wiggled around the wires, now problems gone so I know it’s my wiring
Old May 11, 2020 | 01:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
Check the wires going to the output sensor on the tail housing of the transmission. Thats for your odometer. The wire were known to break in side the connector.
