Random High Idle - 2006 Dodge Ram 1500 5.7
Old May 12, 2020 | 07:14 PM
JeremySalt's Avatar
JeremySalt
Default Random High Idle - 2006 Dodge Ram 1500 5.7
2006 Dodge Ram 1500 Hemi
All fluids have been changed this year.
Using only regular Shell gas.
My truck isles high then back to normal often. At stop lights or running on parked. She’ll idle a couple hundred rpm for a second then back down.
Any ideas how to get smoother consistent idle?
Old May 12, 2020 | 09:31 PM
That is generally the sign of a vacuum leak.
Welcome to DF!
Old May 12, 2020 | 10:46 PM
JeremySalt's Avatar
JeremySalt
Thanks!
Any idea where vacuum leak could be coming from?
Old May 13, 2020 | 07:17 AM
Wherever there is a vacuum line. , also potentially any intake manifold gasket surfaces. Use something like carb cleaner, and spray it around various places with the engine at idle, if the idle changes, you are in the right neighborhood.
Old May 13, 2020 | 08:32 AM
Moved to 3rd gen Ram section so this will get more visibility. Welcome to DF!
