no brake pedal help
Old May 25, 2020 | 04:26 PM
bud2's Avatar
bud2
Default no brake pedal help
hi I had to replace ball joints on my 2004ram 2500 4x4 5.7 the other day an noticed inside brake pads worn ordered new rotor,caliburs ,brake pads an new line from calibur. after bleeding cant get good break pedal goes to floor looked over everything caliburs on correct bleeders on top . does anyone have idea whats up I was going to bleed rear but bleeders frozen got them soaking now.
Old May 25, 2020 | 04:50 PM
Pump up the brakes with engine off. Do you eventually get a firm pedal?
Old May 25, 2020 | 05:32 PM
95RAM360's Avatar
95RAM360
Best way to free stuck bleeder screws, and I deal with this on a weekly basis at my shop....no penetrating oil needed...as I’ve never had it actually work on anything....anything seized you want heat
get a torch, or buy a nozzle and a little camp propane tank (small ones obviously) heat it up, doesn’t have to be cherry red...heat then tap on screw lightly with hammer, heat, tap with hammer..do this a couple times and check if it broke free, if not then keep heating and tapping, it WILL come out...I’ve always extracted every one with this method....used this method on broken manifold studs, intake studs (I have a real torch for those and anything broken flush I weld a nut to it but that’s not in your case) but the method is the same. It has always worked and I’ve never had to drill and tap any broken bolts
Old May 25, 2020 | 06:51 PM
bud2's Avatar
bud2
yes I do than start up an loose it
Old May 25, 2020 | 07:55 PM
I suspect there is still air in the system somewhere, or, you have a fluid leak somewhere. (and not necessarily where you can see it..... )
Old May 31, 2020 | 08:22 PM
bud2's Avatar
bud2
fixed didnt know dodge r motorious 4 break master cylinder after bleeding replaced . master cylinder bleeded system now ok wow 4min was thinking about buying a new GMC
Old May 31, 2020 | 08:25 PM
bud2's Avatar
bud2
2 woods 2morr
