Scoped my catalytic converter. Is this normal?
Old Jun 6, 2020 | 10:02 PM
Prismatic's Avatar
Prismatic
Default Scoped my catalytic converter. Is this normal?
Was trying to diagnose a perceived lack of passing power on the highway. Considered the potential for a clogged cat.
Ran a scope in through the upstream O2 hole. Seems mostly clear, but it does appear cracked in one spot. Is this normal or should I probably consider changing it?
Thanks!
2003 Ram 1500 Quad Cab 4x4 5.7l
Old Jun 7, 2020 | 08:52 AM
Do a pressure test. Just drill a small hole in the exhaust before the cat, stick your gauge in there, and see what pressure is at idle. If it's over 2PSI, replace the cat.
Old Jun 13, 2020 | 09:07 PM
rwaltemate's Avatar
rwaltemate
Not sure... mine "fell off" and was replaced by a little cheater chip that varies the voltage just enough for the downstream O2 sensor not to though an engine code.
