Clutch fan
Old Jun 7, 2020 | 07:58 AM
Dakota Comstock's Avatar
Dakota Comstock
Default Clutch fan
I have a 03 Ram 1500 5.7 4WD and it has been setting I was trying to figure out why it won’t start it turns over and has fire/fuel. The clutch fan doesn’t move and seems to be locked up could this be the problem
Old Jun 7, 2020 | 08:33 AM
TrueDogman's Avatar
TrueDogman
It should still start. Is the water pump turning? clutch will need to be replaced after you get it running tho.
Old Jun 7, 2020 | 05:01 PM
Dakota Comstock
I got it running but the water pump is semi locked up (will not hardly turn) so I think that’s the problem
Old Jun 7, 2020 | 09:03 PM
Alex Medeiros's Avatar
Alex Medeiros
You should replace it asap then. You don't want to risk hurting your engine.
