Need Help! No key FOB and in theft mode
Old Jun 7, 2020 | 11:29 PM
Adrian Pacheco-Cervantes's Avatar
Default Need Help! No key FOB and in theft mode
Hey there guys! I just bought a 2006 Dodge RAM 1500 from an auction. It does not have a key FOB just a grey key. the red dot keeps flashing on the dash when I try to start it. It doesn’t click but it does prep the gas pump. It also won’t allow a scan tool to read it. I’m stuck and need to get this running! Anything will help
I should mention that the driver side door seems to be broken because it won’t lock or unlock with the grey key.
Old Jun 7, 2020 | 11:59 PM
fj5gtx's Avatar
fj5gtx
Probably the dealer, maybe a locksmith can help you out.
Old Jun 8, 2020 | 06:09 AM
ol' grouch's Avatar
ol' grouch
Why was it at an auction? Insurance theft recovery? Repossession? You may need to see the dealer to get it going. As for the door, if the key works in the other door, the linkage may be broken or disconnected inside. I'm thinking someone force entry into it and knocked one of the plastic clips off inside the door assembly. You can usually get replacement clips for the linkage. The computer though, that will be the dealer as it's meant to stop theft. My '03 didn't have a fob, just a key. However, more deluxe models may. The early 2000's it was hit or miss on fobs.
