07 Dodge 3500 5.9 Cranks but won’t start
Old Jun 8, 2020 | 09:41 PM
Brennenatkinson1@gmail.com's Avatar
Default 07 Dodge 3500 5.9 Cranks but won’t start
07 dodge 3500 5.9 24v
132k original miles
6sp man. Trans
Hey guys, I was cruising down the road pulling a small grade when all of a sudden my truck started losing power. Threw two codes for the #2 injector open circuit and group #1 injector open circuit.
pulled the valve cover, tested the resistance on my injectors. 1, 3,4,5 and 6 were all .3-.8 ohms. #2 was 3.0 ohms. Found the culprit and replaced it (under warranty) decided to adjust my valve lash while I was there. (0.010 intake- 0.026 exh.) Torqued to spec, got her all buttoned up, low and behold no start.
It cranks and cranks but won’t start. Tried to start it allowing the starter to cool in between starting attempts to no success.
I’ve adjusted valve lash a hand full of times along with swapping/changing injectors. My only thought is air is in the rail/line somewhere.
Also- I am baffled at the site of oil being under/inside my grid heater port. (What is your thought on this?)
Your advice is greatly appreciated. Thanks
Old Jun 9, 2020 | 08:07 AM
May be air in the lines..... is the PCM whining about anything else?
I think some oil ingestion is normal on the diesel, I believe it comes from the turbo..... Not 100% on that though. Everything I know about diesels is written on the inside of my left eyelid.
Old Jun 10, 2020 | 02:08 PM
I personally think it’s air in the lines. It’s supposed to be a “self bleeding” system so I figured it would be worked out by now. The PCM isn’t throwing any codes beside the CAM sensor now.
Old Jun 10, 2020 | 03:22 PM
I would expect it won't run without good cam sensor signal.
