Rearend swap
Old Aug 27, 2020 | 09:58 AM
Lou1238's Avatar
Lou1238
Default Rearend swap
I have an 04 Ram SLT 2WD with typical 9 1/4 rearend. I'm hearing a grinding noise mainly on drivers side. I replaced my wheel bearings a few months ago, and when I opened diff, I found a needle in the bottom of the housing. I think it came form the D/S carrier bearing. Here's my dilemma, should I by a bearing rebuild kit and rebuild it or I can drop a 3.92 Posi in it? I can get a complete rearend for $400. All i would need to do is unhook brakes, shocks and springs and replace.
Any advice would be appreciated.
Old Aug 27, 2020 | 11:19 AM
I would go for the complete rear swap. Likely end up being cheaper.
Old Aug 27, 2020 | 01:18 PM
Alex Medeiros's Avatar
Alex Medeiros
+1 on that.
Old Aug 27, 2020 | 08:47 PM
Chazwel's Avatar
Chazwel
$400 rear end? junkyard?
Old Aug 27, 2020 | 09:38 PM
Alex Medeiros
Best bet would probably be to get the complete one.
Old Aug 30, 2020 | 04:09 PM
Dave's Wifeyo's Avatar
Dave's Wifeyo
Default 2005 Rumble bee
Just bought a 2005 Rumble bee from my dad, and he has replaced the rear end twice. The original smoked right after having the recall done at our local Dodge. The first replacement was good, everything worked (too bad it was pretty worn out), but the second one came from an '06 and now the speedometer won't work....any ideas?!
Thank you in advance!
Old Sep 3, 2020 | 03:15 PM
Lou1238's Avatar
Lou1238
No. local guy that buys wrecked dodges. Engine blew in this truck.
