Low vacuum on highway
Old Sep 12, 2020 | 07:16 PM
pickford78's Avatar
pickford78
Default Low vacuum on highway
Hey everyone, I've been getting horrible gas mileage on the highway, around 11mpg. This is in a 4wd 5.7 2008 quad cab with mds. One thing I noticed is that at idle I have great vacuum at 22.8 inches, but on flat road driving 55mph the vacuum reads as low as 3 inches. Anyone have an idea that could relate to this?
Old Sep 12, 2020 | 08:48 PM
How many miles on it? What size tires? Has it done better in the past? How much better?
Old Sep 12, 2020 | 10:14 PM
pickford78's Avatar
pickford78
it only has 70k miles on it I have 17 inch rims. I pulled the oil cap and didnt notice any signs of blow by
Edit: I have only owned the truck since march. It was better when I bought it, but seems to have declined since
Old Sep 12, 2020 | 10:25 PM
Original O2 sensors? Might try changing the front ones first, and see if that makes any difference. NTK or Denso sensors only please.
Old Sep 13, 2020 | 09:36 PM
pickford78's Avatar
pickford78
Just ordered a set, they'll be here next monday. I'll let you know if that fixes anything. Thanks for your help
Old Sep 14, 2020 | 10:17 PM
rtmtrrdr's Avatar
rtmtrrdr
When was the last time a tune up had been done?
Old Sep 14, 2020 | 10:25 PM
pickford78's Avatar
pickford78
About a month ago I changed the plugs, they were worn down a bit, but in they didnt look too bad, all the same. The MAP sensor was changed at the same time, without any change in performance.
Old Sep 20, 2020 | 07:51 PM
pickford78's Avatar
pickford78
Just tested it out on the highways with the new o2 sensors, I'm getting the same
Old Sep 20, 2020 | 08:36 PM
How does it run? I only really expect to see good vacuum at idle, when the throttle is closed.......
Old Sep 20, 2020 | 08:47 PM
pickford78's Avatar
pickford78
the truck runs excellent, it just gets terrible economy.
