Where is the flasher?!
Bwahahaha.....someone isn't used to working on modern electronic vehicles lol. No flasher dude, those were gone by 1994ish. Blinkers are controlled by a computer module. You either find LED's that are fully OEM compatible or as @Alex Medeiros mentioned, you add resistors to make them work correctly.
So the dude doesn't know that these trucks don't have changeable flasher modules... Who cares?
Here is a fun site for you. Unfortunately your truck, like many 3rd Gen Rams don't have turn signal flashers that can be replaced. What you will have to do is pick up a load resister instead.
As you can see in that link above the flasher option is grayed out, however the load resister option isn't.
This is actually my favorite site to go to because they have LED bulbs for every possible situation on vehicles.
Hope this helps.
You could just answer the question and not be a dick about it. That is a very reasonable thing to do.... Or you could have scrolled by and let someone else handle this one.
I agree with Shadow Death.... You do tend to be a bit..... abrasive...... Really don't need that here.
So much toxicity over nothing. You could just answer the question and not be a dick about it. That is a very reasonable thing to do.... Or you could have scrolled by and let someone else handle this one.
https://www.superbrightleds.com/vehi...load-resistors
Hope this helps.
Hope this helps.
