Engaging Cruise Control Creates Bog? - 4.7L
Old Nov 27, 2020 | 07:52 PM
RedRam2002's Avatar
RedRam2002
Default Engaging Cruise Control Creates Bog? - 4.7L
Was driving on the highway today and decided to try the cruise control for the first time on this Ram (just insured it last week) - cruise control light came on and I hit the set button but vehicle started to slow down instead of holding speed. Tried once more but the same thing happened. After that I am getting a bog around 1600 rpm roughly and at about 25mph multiple times. Tried turning off O/d but same thing. Read an old post about someone who had same issue after trying to engage cruise control.
Could something in the cruise control setup be sticking/engaging still and be causing the bog?
Old Nov 27, 2020 | 09:50 PM
Alex Medeiros's Avatar
Alex Medeiros
Do all the buttons on the steering wheel work for the cruise control?
Old Nov 28, 2020 | 03:07 PM
RedRam2002's Avatar
RedRam2002
Not sure, cruise "on" button works and "off" but "set" didn't engage it.
Old Nov 28, 2020 | 04:56 PM
Alex Medeiros
Is the set button sticking? Might need a replacement assembly to see if that's the issue.
Old Nov 29, 2020 | 09:42 AM
Buttons should be easy to test, all they do is modify a voltage signal from the PCM, just need to know what the correct resistance values are, and see if yours are close.
