Window swith not work
Old Jan 25, 2021 | 05:23 PM
dschweers's Avatar
dschweers
Default Window swith not work
Passanger window swith will lower but not raise. Have hooked up 12 volt direct to raise window. Replaced passenger swith and have the same issue.
Old Jan 25, 2021 | 05:49 PM
Will the window go up if you hit the switch, and help the window up?
Old Jan 26, 2021 | 07:23 AM
dschweers's Avatar
dschweers
Default Actuator works
I've used a 12volt sla battery and it drives the actuator up and down with no problems. I just switch the leads.
Old Jan 26, 2021 | 09:29 AM
If the switch works down, then, you have power at the switch.... so, gotta be an issue on the ground side of the switch then. Might be the switch, might be the ground wire AFTER the switch.
Old Jan 26, 2021 | 05:42 PM
Dodgevity's Avatar
Dodgevity
Sometimes the culprit could be the master switch, thru which all the switches run.
