2005 Ram 1500 hemi - correct Ratio programming
Old Jan 31, 2021 | 02:49 PM
Jonah80's Avatar
Jonah80
Default 2005 Ram 1500 hemi - correct Ratio programming
Hey all,
I am looking for a l little Info on the best way to have Ratio programming corrected.
Cruise control works but won’t set at anything above 55mph.
any suggestions would be great.
thanks
Old Jan 31, 2021 | 02:57 PM
What did you change?
Old Jan 31, 2021 | 06:56 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Did you change tire size?
Old Jan 31, 2021 | 09:14 PM
Jonah80's Avatar
Jonah80
Nah haven’t changed anything, the tires were on when I bought it, although I have changed the front wheel bearings. This issue was still present before I changed them out.
Old Jan 31, 2021 | 09:23 PM
Is your speedometer off?
Old Jan 31, 2021 | 09:30 PM
Jonah80's Avatar
Jonah80
Not that I am aware, I will check it tomorrow and get back.
Thanks.
Old Jan 31, 2021 | 09:55 PM
It would have to be WAY off... as I think cruise should set at anything below about 85 or so??? I think that's a difference you would certainly notice.
Old Feb 1, 2021 | 10:36 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Correct, 3rd gen (at least early 3rd gen) CC is good up to 85mph. Thing is, gear ratio doesn't affect the speedo, only tire height. Pinion factor only needs to be altered in response to tire diameter changes. Have you looked to see if you have any codes? Sometimes you'll have a stored code that screws things up. Doesn't happen as often with the later switches asit does with the 02-03's but sometimes there's a fault within the switch itself.
Old Feb 1, 2021 | 10:55 AM
Jonah80's Avatar
Jonah80
Ok, brill thanks and how would I then alter the pinion factor?
Old Feb 1, 2021 | 11:03 AM
Need a pretty high-zoot scan tool for that. But, any national tire chain should be able to deal with it for you. (for a nominal fee.....)
I don't think that is your issue though.
