Hemi down
Old Feb 9, 2021 | 11:03 PM
Crazymexhanic's Avatar
Crazymexhanic
Default Hemi down
Hey y'all first time on here. I have an 05 ram 5.7 130k miles. Religiously serviced with synthetic since new. I was omw home from work cruising around 70 went to pass someone and truck revved up but didn't go anywhere so I thought well I caught the bad transmission flu and so I chilled and just cruised home thought I would get off at earlier exit keep rpms lower when I did truck cut off and wouldn't start. I'm like aw alternator went out. So I got it towed to house and for s*#ts and giggles I tried to start it started right up but had a hard knock. Idk where to start. Obviously tear down but I am scared to bc of the price tag going up. Any thoughts before my pocket starts crying?
Old Feb 10, 2021 | 09:33 AM
Knock, or tick? See if you can determine where the noise is coming from, and go from there. Might be easier to simply toss a motor at it......
Old Feb 10, 2021 | 12:48 PM
Dodgevity's Avatar
Dodgevity
Have you checked the oil level?
Old Feb 10, 2021 | 05:24 PM
Crazymexhanic
Default Knock for sure
Yeah it's definitely a knock already had the tick. Was planning on headers soon but ya know. Also forgot to mention that it won't stay running it will start right up but I have to give it gas to keep running. It was little low on oil but no more than it usually makes disseapear. I was thinking motor but there is certain centiment to the entire vehicle as it was my father's and he has cancer.
Old Feb 10, 2021 | 09:40 PM
Take off the serpentine belt, start the motor, noise still there? (don't run it very long without the belt......)
Old Feb 10, 2021 | 10:30 PM
Crazymexhanic
Default Belt
I'll try belt off in the AM or after work depending when I wake up what does it mean if knock is still there?
Old Feb 11, 2021 | 09:36 AM
It means its not one of the accessories making the noise.....
Old Feb 11, 2021 | 10:07 AM
jrsick's Avatar
jrsick
You've described both a transmission and engine problem in your initial post. For the knock, generally engine knock occurs gradually as rod bearing gaps increase. You have changed the oil regularly and used quality oil, so I would not suspect internal damage yet. When you do the check heyyou recommends and if it still knocks, try to locate the exact source of the knock. A two foot length of garden hose that you hold to your ear is one technique for locating knocks.
The first place I'd look is fuel management. Is it possible you have low octane gas or water in your tank? There are products to help with water in fuel, iso heet being one of them. I'd recommend getting 91 octane gas and adding iso heet and a fuel injector cleaner.
Also consider cleaning the fuel injectors separately. At 130k miles it is a good ideas anyway.
Old Feb 11, 2021 | 11:00 AM
ol' grouch's Avatar
ol' grouch
If it's definitely a knock, don't run it more than you have to. If it throws a rod you lose your core charge if you put another engine into it. A knock can often be rebuilt. A thrown rod may perforate the oil pan or even the block making it worthless for rebuilding.
Old Feb 16, 2021 | 10:08 PM
Crazymexhanic
So ran with off still knocking. It gets nothing but premium gas. I run a bottle of seafoam once a month through it. I'ma start tearing down soon as it warms up and just face whatever the math is. Just hate it.
