2004 5.7 Hemi Vacuum Problem
I ran the fuel very low. When I filled up and got back on the interstate it started to miss and run terrible. I barely made it to the next exit and there was an O'Rielly's. I got to O'Rielly's by pumping the gas to keep it going and it died in the parking lot. It had multiple codes. Long story short, I've replaced the EGR Valve, Fuel Pump, O2 Sensors and injectors. I replaced the passenger side injectors first as that's what the code said. After each one of these part replacements, I tried the truck and it would only run if I kept pumping the throttle, no change. The last thing I did was replace the drivers side injectors. I had to unplug the booster vacuum hose to better access the fuel rail. When I finished the drivers side it started up and in a couple of minutes was idling on it's own. O' yea, while I was replacing the pump I checked the fuel tank and it was very clean. I had already poured a bottle of injector cleaner and sea foam as well. The truck set and idled great while I was putting the bed back on the truck. So I went for a test drive. The truck was running fine but when I hit the brakes they were very hard. I had forgotten to re-attach the booster vacuum hose. Simple fix. I pulled over hooked up the hose and the truck died. I finally got it started and it was back to square one. It ran the same as the first night it died. I can only assume it's a vacuum related problem. Could it be a cracked throttle body??? Has anybody ever heard of this type of problem??
Any help will be appreciated.
Thanks
Rickey, frustrated in Murfreesboro, TN.
Thanks
TrueDogman,
Thank you for the advise.
I'm old enough to remember when if a vehicle had gas, fire, and a vacuum hose to the distributor you were usually good to go.
I'll read up on the map sensor!
It's just an idea...with the vacuum leak caused by the brake booster hose....I would think the MAP sensor would be sensing low absolute pressure and subsequently the ecm would command more fuel?? Doesn't make sense with the running low on fuel time frame tho....again just an idea.
On another idea...with all the pumping of the gas pedal....did this cause an issue with the throttle body or valve ??
Trending Topics
Yea,
I'll get back on it this weekend. I'll unplug the map sensor then I'm gonna track down all of the vacuum lines. The funny part is that it seems to run fine
with the booster hose unplugged. Thanks for you help.
