Do 05 2wd's have torsion bars?
Old Feb 7, 2008 | 04:09 AM
dodgeguy_20's Avatar
dodgeguy_20
Default Do 05 2wd's have torsion bars?
Hey guys I am new to the board and tried to search this subject but couldnt find anything. I have heard of people lifting the front ends of their trucks by using torsion bars and was wondering if my 05 2wd has these or do they just come on 4wds? Any help is appreciated it.
Old Feb 7, 2008 | 05:09 AM
mikey0302's Avatar
mikey0302
Default RE: Do 05 2wd's have torsion bars?
Greetings, what I am gathering here is that you have coil over spring. The easy way to tell obviously is if you have a big spring mounted at each wheel. You would be able to see them by just looking at the wheel well. If you have the A frame torsion assembly you woul notice a large steel bar that comes out from just behind the ball joint assembly and will go back toward the rear and will stop about the same distance as the door underneathe the truck. The torsion is mounted using a tension bolt mounted into the crossmember. I hope this helps. I just put a levelling kit into my 05 Ram 4x4. There is a few threads here discussing this, I think I remember one of the members saying that the 2wd's have coil over setup.
Old Feb 7, 2008 | 05:18 AM
mikey0302's Avatar
mikey0302
Also check this thread
problems with 3" leveling kit?????!
Old Feb 7, 2008 | 02:01 PM
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
04 and 05 Trucks have coil springs....02-03 have Torsion bars.
Old Feb 22, 2021 | 02:13 PM
Dylan Childress's Avatar
Dylan Childress
Default 02 dodge ram
Okay well if so prove this cause as i last checked they dont
Old Feb 22, 2021 | 02:14 PM
Dylan Childress
the 02 doesnt have torsions
Old Feb 22, 2021 | 05:51 PM
Alex Medeiros's Avatar
Alex Medeiros
13 years later
Old Feb 22, 2021 | 06:59 PM
Originally Posted by Alex Medeiros
13 years later
No point rushing into anything, right?
Old Feb 23, 2021 | 09:11 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
