Driving Vibration
Old Feb 28, 2021 | 03:59 PM
dgurrola's Avatar
dgurrola
Default Driving Vibration
I have a 2005 Ram 1500 2WD. I get a vibration at about 30 MPH. I have rotated and balanced tires, fixed an exhaust manifold gaskets leak, replaced sway bar end links. No check engine light is on and I have jacked it up to test to see if there is play on the tire to check the ball joints. No shiny spots on the drive shaft at the U joints. Only vibrates when accelerating or maintaining speed. Any idea what it could be?
Old Feb 28, 2021 | 05:15 PM
Alex Medeiros's Avatar
Alex Medeiros
When's the last time you replaced the pads & rotors? Maybe you've got an uneven rotor somewhere?
Old Feb 28, 2021 | 05:30 PM
Dodgevity's Avatar
Dodgevity
Brakes would vibrate when braking.
Check your driveshaft bolts, make sure they're all tight. Also check your motor mounts and harmonic balancer.
Old Feb 28, 2021 | 06:38 PM
Pinion nut?
Old Feb 28, 2021 | 09:24 PM
dgurrola's Avatar
dgurrola
I have not checked motor mounts. Thanks!
Old Feb 28, 2021 | 09:25 PM
dgurrola's Avatar
dgurrola
Pinion nut?
I have not checked that either. Thanks
Old Mar 2, 2021 | 06:59 PM
b2benedict's Avatar
b2benedict
Did you find the fix for this?
