2wd 5.7 to 4wd with 4.7l transmission
Old Mar 5, 2021 | 10:08 AM
Southafrican456's Avatar
Southafrican456
Default 2wd 5.7 to 4wd with 4.7l transmission
Hey guys,
Hope this isn't against community guidelines or anything, I have a 2005 dodge ram 1500 with the 5.7l hemi 2wd. I'm wanting to convert it to a 4wd, I can pick up the front axle, transfer case and transmission off a 2003 dodge but it's the 4.7. Would the transmission work with my engine?
Any help be appreciated guys. Thanks!
Old Mar 5, 2021 | 12:17 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Same transmission, but that isn't your issue here. 2005 2wd has coil springs and shocks. 2005 4wd uses torsion bars. Totally different front suspension.
Old Mar 5, 2021 | 01:41 PM
Southafrican456
Would I be able to change out the front end? Pretty sure I can get the front suspension with the transmission and the rest?
Old Mar 5, 2021 | 02:42 PM
If you can do cutting/welding/other fab work, it's doable, but, a LOT of work..... and getting it right is gonna be an exercise. Might be easier/cheaper to sell what you have, and buy what you want.
Old Mar 5, 2021 | 07:31 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Either fab work or frame swap.
