Using penetracting oil on upper lower ball joints the day before replacing ?
Old Mar 29, 2021 | 07:52 PM
Pelicansplash's Avatar
Pelicansplash
Default Using penetracting oil on upper lower ball joints the day before replacing ?
Simple ball joint replacement prep Q ?
Pre penetrating oil a few days ahead of removing lower upper ball joints .
would help make things easier ?
Just like. leaf spring nuts n bolts helped out too pre lube .
Old Mar 29, 2021 | 08:03 PM
Prismatic's Avatar
Prismatic
You can. Personally I think all penetrating oils are -- well -- no pun intended, snake oil. I don't think i've ever seen an oil able to creep into a rusted fastener. Though it helps immensely as soon as you can break them free.
Old Mar 29, 2021 | 09:14 PM
Certainly can’t hurt.
Old Mar 29, 2021 | 11:14 PM
Pelicansplash
So I like both answers so far.
BUT I CALL AND RAISE YOU GUYS by 2..
Metal Is porus but not 100%. Soak your nuts in
it for a day.
Second Kris Fix has a ball joint replacement video with
a tip of feeding your ***** overnite in the freezer .
Blue and Frozen *****. I don't think ide be calling her for a second date.
Old Mar 30, 2021 | 07:37 AM
jjolson68's Avatar
jjolson68
I just replaced mine - 150,000 miles, original equipment, Denver area its whole life. PB Blaster made me feel good, watching it bubble, but it didn't penetrate.
Old Mar 30, 2021 | 09:17 AM
If you tap on the fasteners in question a bit, it helps.
Old Mar 30, 2021 | 05:49 PM
Pelicansplash
its shocking vibration.
ooh yes I remember the old days when the wife used to let me in the bedroom at nite.
Old Mar 30, 2021 | 05:52 PM
Pelicansplash
I haven't watched yet but I'm going too in about 3 minutes.
its a video about this topic of pen oil and if it really works.
