3rd gen 4.7 small ticking
Old Apr 12, 2021 | 08:35 PM
RockyDon's Avatar
RockyDon
Default 3rd gen 4.7 small ticking
i have a 2002 1500 4.7L and there is this small ticking noise very very tiny but i can still hear it it sounds like it’s coming from bottom of engine anyone have any clue or is this just normal
Old Apr 13, 2021 | 03:47 AM
Prismatic's Avatar
Prismatic
I had a 4.7 for three years and it ticked more than my buddies 5.7. Could be worn timing chain guides but really, anything is just conjecture at this point.
Old Apr 13, 2021 | 05:42 AM
jrsick's Avatar
jrsick
Exhaust leak and weak lifters can cause ticking.
Unlikely that the noise is a serious problem, or originating from engine bottom end, if that is your concern.
Old Apr 20, 2021 | 03:46 AM
RockyDon's Avatar
RockyDon
i haven’t been on here in a while but is there anything i should look for to know?
Old Apr 20, 2021 | 07:37 AM
Dodgevity's Avatar
Dodgevity
Do you hear that same ticking louder at cold start? Usually it's the lifters, but the ticking should subside once they prime with oil. I run 0W20 full syn, so oil delivery is quicker to the upper reaches during cold start.
Needless to say, keep your oil level up. Check it and top it off every week or two if losing oil.
Old Apr 20, 2021 | 09:18 AM
ramario99's Avatar
ramario99
I recently discovered my 5.7l had an exhaust leak caused by a broken manifold bolt on the passenger side. You could see it from the bottom if you got under it.
Old Apr 20, 2021 | 05:04 PM
RockyDon's Avatar
RockyDon
i hear it after a lil bit of it running but it’s not loud at all it’s very quiet i don’t think it’s something big but i’m just making sure
Old Apr 20, 2021 | 06:04 PM
jrsick's Avatar
jrsick
There are videos for replacing broken manifold bolts. I recommend you get the wheel and fender well off and truck front end on jack stands. 4 jack stands is better than 2. Finesse the bolt out and avoid using brute force. You've got to break the rust bond before putting any torque on the bolt.
Do you feel certain that this is the only leak? The flange connection just forward of the cats is good? It should be unless someone has put a wrench on the flange bolts.
Old Apr 20, 2021 | 06:22 PM
Not just the injectors you are hearing?
Old Apr 20, 2021 | 08:10 PM
RockyDon's Avatar
RockyDon
i don’t think so it sounds like it’s coming from the bottom i’m not sure
