Ring gears
Old Apr 24, 2021 | 02:34 AM
Matthew White's Avatar
Matthew White
Default Ring gears
When swapping to 9.25 posi and reusing old ring gears. Do you need to use the starter ring gear that sits right behind it? What does it even do? I’ve seen several people not have them on there differential. Do I even need it?
Old Apr 24, 2021 | 06:38 AM
jrsick's Avatar
jrsick
You may be referring to the ABS tone ring, aka exciter ring. Look that up and see if that is the part you are asking about.
Old Apr 24, 2021 | 08:19 AM
Matthew White
It’s the starter ring gear or tooth ring gear sits right behind the ring gear.
Old Apr 24, 2021 | 09:27 AM
That's the tone ring for the rear wheel speed sensor, and yes, that absolutely needs to be in there.
Old Apr 24, 2021 | 09:38 AM
Matthew White
ok thanks
Old Apr 24, 2021 | 11:34 AM
jrsick's Avatar
jrsick
The gear in the differential has nothing to do with the starter. It sends a signal to the ABS sensor. Since you have that then your truck has rear wheel anti lock brakes. Trucks without that gear do not have RWAL.
Old Apr 24, 2021 | 05:15 PM
Matthew White
ok yeah that makes sense. Thank you
