2006 Dodge Ram 1500 5.7 SLT Quad Cab 4x4 Driver Side Intermediate Shaft ( CV AXLE )
Old May 27, 2021 | 11:11 PM
brucec241's Avatar
brucec241
Default 2006 Dodge Ram 1500 5.7 SLT Quad Cab 4x4 Driver Side Intermediate Shaft ( CV AXLE )
HELP!!
All the video I see they show either it come out with the cv axle or they just give a couple good hits and it come right out. Well i been hitting and hitting and hitting and hitting did i mention hitting. I cant get the darn thing to come out it is rounded so I need to replace. Has anyone had this problem of getting this shaft out, TY
Old May 29, 2021 | 10:16 AM
brucec241's Avatar
brucec241
Default my solution
well no response, hmmm couldn't be only person that had this issue; but either way right or wrong. my solution i grounded down the sides enough to get a ball joint seperator or fork on it, then put a bar right below shaft and frame where lower control arm goes, the fork was wedged on top of the bar and i gave it a good hit with a heavy hammer. came right out. hope helps if anyone else ever has same issue
Old May 30, 2021 | 09:47 AM
Creative solution.
I've also seen folks drill into the end of the stub shaft, thread it, put in a bolt, and clamp a slide hammer to it.......
Old May 31, 2021 | 12:49 AM
marcelin's Avatar
marcelin
I put the truck on 4x4 chuck the wheels put the truck id drive the shaft was spinning took a grinder held it on the shaft that was spinning cut a groove 1/4 wide with a square shoulder mounted a slide hammer and our it came. while hammering I was pushing the shaft in so the retaining clip would travel a bit with each hit of the slide.
