i don’t know if coolant is getting in the engine
Old Jun 15, 2021 | 05:59 PM
RockyDon's Avatar
RockyDon
Default i don’t know if coolant is getting in the engine
i replace everything water pump thermostat and radiator and i put coolant in bled it and everything it didn’t go down i went for a drive got it up to temp i thought it would suck a bunch in when the thermostat opened but it didn’t
Old Jun 16, 2021 | 06:40 AM
jrsick's Avatar
jrsick
I apologize Rocky, but I'm not sure what your situation is, or what you are asking. Are you losing coolant? If so, I'd recommend you put a sheet of cardboard or plastic under your truck overnight and see if you have any puddles in the morning. If no puddles, then most likely problem is head gasket, but could be bad radiator cap or leaky heater core. Have you had an over temp on your engine recently?
I recommend do some research on a compression check and leak down test.
You could also try testing if combustion gas is getting into your coolant. Remove your radiator cap while the engine is cool, and start the engine with the cap off. Let engine warm up and look for bubbles in the radiator. If you get bubbles then you have a head gasket leak. But there are conditions where you have a leaking head gasket and no bubbles, so it's just one test.
Old Jun 16, 2021 | 03:45 PM
ol' grouch's Avatar
ol' grouch
If bled properly, then there won't be any air in there. No air, it won't go down as everything is full.Since the air burps out into the top tank, if it doesn't over heat, you probably did a good job and it's done.
Old Jun 17, 2021 | 04:17 PM
RockyDon's Avatar
RockyDon
i opened the bled hex thing and opened the cap let it run and squeezed on the tubes a bit should that be good
Old Jun 17, 2021 | 06:35 PM
ol' grouch's Avatar
ol' grouch
It's been a while since I worked on a 3rd gen truck but if my memory is correct, the bleeder gets the one air pocket out and anything else burps into the top tank. I never had any coolant issues after the repairs.
Old Jun 19, 2021 | 12:20 PM
Dodgevity's Avatar
Dodgevity
The thermostat is not a perfect seal. It's designed to allow coolant (and air) to pass through, even when fully closed, although at a much lesser rate. The important thing to do is burp with the front higher than the rear.
Drive it till hot and wait till it cools off.....if the level is up to the neck, overflow tank up to max when it fully cools off, it's time for a beer.
