Coolant Leak / 2008 Ram1500 4.7 100k
Hi everyone.
My truck started leaking coolant a few days ago. In that few days (about 5), I noticed a small puddle I thought was A/C condensate at first started growing in size and became on obvious orange color. Now, it leaves a much larger puddle and leaks even w/out being pressurized.
Looking under the truck, it appears to leak from the front bottom of the engine. The water pump is nearby, I'm assuming it's coming from there, but can't tell with certainty because it's actually all over the front of the engine.
At a minimum, I'm thinking water pump gasket. Should I go ahead and do the whole water pump though? Anything else while I'm in there? Anything in particular I should watch out for?
Truck is about 50mi shy of 100k. I've only had it for the last 7k though.
BTW, right before leak started, I towed a boat (about 12-1300 lbs) to the lake. Weather was warm (75 ish), and there was a couple mountain passes. Previous owner only towed a small utility trailer on occasion prior to me.
I probably stuffed this with too much detail, hopefully it's helpful at least.
Thanks in advance for any help.
It's most likely the water pump itself and not the gasket. The water pump is designed to leak as the seals start to fail, and has a weep hole on top of the pump for this purpose.
Definitely replace the pump, and I rec doing a coolant change also, along with a new thermostat.
Be sure to keep up with water pump bolt location during the change. They are all the same size thread but different lengths. Also use a torque wrench because it's easy to strip the block threads.
Thanks for the info.
When looking at water pumps, it looks like I can get a Mopar pump for about $250. All others are under $100. Most likely to buy from Napa Auto. Would one of these cheaper ones be a good idea? If so, should I go with a metal or plastic impeller? I can imagine pros/cons with each.
Thanks again
Thanks again
RockAuto has a Gates with metal. Around $40. WaterPump
Or AC Delco around $45 with metal.
5% Discount Code: 68B102D0378118
Expires: July 14, 2021
Please enter this code in the ‘How Did You Hear About Us’ box to receive the discount. Please enter ONLY the discount code, no other words or numbers. All orders are placed online and the discount code must be entered before an order is submitted to receive the discount.
Trending Topics
Don't go replacing parts till you're sure of the leak source. Get under that thing with a strong light or UV light (I found that coolant glows under UV without any additive).
If you end up needing a pump..... I got this GMB for my 4.7. GMB is a good bearing maker, which is the thing that usually fails.
https://dodgeforum.com/forum/2nd-gen...t-removal.html
Thanks for the great info.
I replaced the water pump and thermostat.
The leak is gone.
Thank you everyone. The UV light idea was particularly useful.
One followup question: I found torque specs for the water pump as 25 and 43 ft lbs. I went with 25. Do I need to go back and tighten these further?
The leak is gone.
